I have tried to modify the button blink example for RPI to add a box to view a variable. I can add to the HMI, however If I reference anything other than one of the RPI outputs in the connection string, the HMI does not work.
I am looking at using this to display temperatures measured by a OW Temp probe.
Any suggestions?
thanks in advance
Hi Darren, this example might help. It uses 1-Wire temperature sensor and displays the value in HMI.
https://github.com/rexcontrols/REXexamp … onExtended
The subsequent discussion about using and configuring 1-Wire temperature sensors connection has been moved to a separate topic.
