#1 2016-03-03 15:04:41
soxso2011
How to call REXLANG Output in WebuDi HMI
I am unable to access REXLANG outputs or inputs or user defined parameters p0-p15 in Webudi. for example
{alias: 'alias: 'HV_AW', desc: 'Hand value', cstring: 'read_mcp3422_task.REXLANG_UI:y13', type: 'AR'}    gives a connection string error. But any other block can be accessed like this.
#2 2016-03-04 00:00:45
josar
Re: How to call REXLANG Output in WebuDi HMI
REXLANG is special, the inputs and outputs can be accessed by the names which you define inside your C code. Connect with RexView, unfold the algorithm tree and you will understand.
#3 2016-03-06 20:45:06
soxso2011
Thanks Sir!
