I am unable to access REXLANG outputs or inputs or user defined parameters p0-p15 in Webudi. for example
{alias: 'alias: 'HV_AW', desc: 'Hand value', cstring: 'read_mcp3422_task.REXLANG_UI:y13', type: 'AR'} gives a connection string error. But any other block can be accessed like this.
REXLANG is special, the inputs and outputs can be accessed by the names which you define inside your C code. Connect with RexView, unfold the algorithm tree and you will understand.
Thanks Sir!
