In my project I want to use several heat and energy meters as sensors, because they are already in place.
These communicate with M-bus. I know there is at least one library developed for that on Linux, but I can't see support in Rex. Is it something that will be added in the near future?
If not, supposing I can get the comms working in Python, what is involved in bringing the values in to Rex?
Thanks!
Evan
Hi Evan,
M-bus is not supported in current version of REX Controls. However it is possible to use some of other 3rd party tools (Node.js, python, ...) for M-bus communication and import the data into REX Controls. There are various methods how to import data to REX:
REST API - https://github.com/rexcontrols/REXexamp … PI_example
UDP/IP - RDC function block
TCP/IP - Rexlang function block
text file - Rexlang function block
Another option is to run an external script from REX algorithm using the EPC block...
Thank you very much for the answer and my apologies for the duplicate question. I thought I had asked this but couldn't find the topic again so assumed I hadn't.
I will try to use python and import...
