#1 2016-12-21 10:00:29
et0
M-bus
In my project I want to use several heat and energy meters as sensors, because they are already in place.
These communicate with M-bus.  I know there is at least one library developed for that on Linux, but I can't see support in Rex. Is it something that will be added in the near future?
If not, supposing I can get the comms working in Python, what is involved in bringing the values in to Rex?
Thanks!
Evan
#2 2016-12-22 14:40:25
Re: M-bus
Hi Evan,
M-bus is not supported in current version of REX Controls. However it is possible to use some of other 3rd party tools (Node.js, python, ...) for M-bus communication and import the data into REX Controls. There are various methods how to import data to REX:
#3 2017-01-11 12:27:57
Re: M-bus
Another option is to run an external script from REX algorithm using the EPC block...
#4 2017-01-12 01:29:02
et0
Re: M-bus
Thank you very much for the answer and my apologies for the duplicate question.  I thought I had asked this but couldn't find the topic again so assumed I hadn't.
I will try to use python and import...
