#1 2015-11-30 19:33:24
soxso2011
Rex and Inskscape communication issue
My computer and raspberry is pinging but html file is not opening. Did all steps using https://www.rexcontrols.com/articles/hm … spberry-pi this tutorial. But final step the HMI file is not opening in browser. All proxy disabled but still jot opening.
#2 2015-12-01 11:21:32
Re: Rex and Inskscape communication issue
Please post here the output of the following commands:
uname -a
cat /etc/*-release
ps ax
What do you see when you enter the IP address of your Raspberry Pi in your browser?
#3 2015-12-02 11:28:07
soxso2011
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 4.1.7-v7+ #817 SMP PREEMPT Sat Sep 19 15:32:00 BST 2015 armv7l        GNU/Linux
pi@raspberrypi ~ $ cat /etc/*-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi ~ $ ps ax
  PID TTY      STAT   TIME COMMAND
    1 ?        Ss     0:05 /sbin/init
    2 ?        S      0:00 [kthreadd]
    3 ?        S      0:00 [ksoftirqd/0]
    4 ?        S      0:00 [kworker/0:0]
    5 ?        S<     0:00 [kworker/0:0H]
    6 ?        S      0:00 [kworker/u8:0]
    7 ?        S      0:00 [rcu_preempt]
    8 ?        S      0:00 [rcu_sched]
    9 ?        S      0:00 [rcu_bh]
   10 ?        S      0:00 [migration/0]
   11 ?        S      0:00 [migration/1]
   12 ?        S      0:00 [ksoftirqd/1]
   13 ?        S      0:00 [kworker/1:0]
   14 ?        S<     0:00 [kworker/1:0H]
   15 ?        S      0:00 [migration/2]
   16 ?        S      0:00 [ksoftirqd/2]
   17 ?        S      0:00 [kworker/2:0]
   18 ?        S<     0:00 [kworker/2:0H]
   19 ?        S      0:00 [migration/3]
   20 ?        S      0:00 [ksoftirqd/3]
   21 ?        S      0:00 [kworker/3:0]
   22 ?        S<     0:00 [kworker/3:0H]
   23 ?        S<     0:00 [khelper]
   24 ?        S      0:00 [kdevtmpfs]
   25 ?        S<     0:00 [netns]
   26 ?        S<     0:00 [perf]
   27 ?        S      0:00 [khungtaskd]
   28 ?        S<     0:00 [writeback]
   29 ?        S<     0:00 [crypto]
   30 ?        S<     0:00 [bioset]
   31 ?        S<     0:00 [kblockd]
   32 ?        R      0:00 [kworker/1:1]
   33 ?        S<     0:00 [rpciod]
   34 ?        S      0:00 [kswapd0]
   35 ?        S      0:00 [fsnotify_mark]
   36 ?        S<     0:00 [nfsiod]
   42 ?        S<     0:00 [kthrotld]
   43 ?        S      0:00 [kworker/0:1]
   44 ?        S<     0:00 [VCHIQ-0]
   45 ?        S<     0:00 [VCHIQr-0]
   46 ?        S<     0:00 [VCHIQs-0]
   47 ?        S<     0:00 [iscsi_eh]
   48 ?        S<     0:00 [dwc_otg]
   49 ?        S<     0:00 [DWC Notificatio]
   50 ?        S      0:00 [kworker/u8:1]
   51 ?        S      0:00 [VCHIQka-0]
   52 ?        S<     0:00 [SMIO]
   53 ?        S      0:00 [mmcqd/0]
   54 ?        S<     0:00 [deferwq]
   55 ?        S      0:00 [kworker/2:1]
   56 ?        S      0:00 [jbd2/mmcblk0p6-]
   57 ?        S<     0:00 [ext4-rsv-conver]
   58 ?        S      0:00 [kworker/1:2]
   59 ?        S      0:00 [kworker/3:1]
   60 ?        S<     0:00 [ipv6_addrconf]
   85 ?        S      0:00 [kworker/0:2]
   86 ?        S      0:00 [kworker/u8:2]
  107 ?        Ss     0:00 /lib/systemd/systemd-journald
  109 ?        Ss     0:00 /lib/systemd/systemd-udevd
  126 ?        S      0:00 [kworker/2:2]
  173 ?        D      0:00 [w1_bus_master1]
  179 ?        S      0:00 [spi0]
  340 ?        S      0:00 [RTW_CMD_THREAD]
  418 ?        Ss     0:00 /usr/sbin/cron -f
  419 ?        Ss     0:00 /lib/systemd/systemd-logind
  426 ?        Ss     0:00 avahi-daemon: running [raspberrypi.local]
  428 ?        Ss     0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
  443 ?        S      0:00 /usr/bin/RexWSTcp
  456 ?        Ss     0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/thd.pid --user nobody /dev/in
  460 ?        S<     0:00 [cfg80211]
  466 ?        Ss     0:00 /sbin/dhcpcd -q -b
  470 ?        S      0:00 avahi-daemon: chroot helper
  495 ?        Ss     0:00 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf
  544 ?        Ssl    0:00 /usr/sbin/rsyslogd -n
  563 ?        Ss     0:00 /usr/sbin/sshd -D
  583 ?        Ssl    0:00 /usr/sbin/lightdm
  592 ?        SLsl   0:00 RexCore -d -l /var/log/rexcore.log -p /var/run/rexcore.pid -r /rex/rexcore/exec.rex -w /rex/hmi
  598 ?        S      0:00 [kworker/0:3]
  601 ?        Ss     0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 107:112
  602 ?        Ssl    0:00 /usr/bin/owserver -c /etc/owfs.conf --pid-file /var/run/owfs/owserver.pid
  608 ?        S<     0:00 [kworker/3:1H]
  611 tty7     Ss+    0:01 /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
  620 ?        S      0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 107:112
  622 tty1     Ss     0:00 /bin/login -f
  623 ?        Ss+    0:00 /sbin/agetty --keep-baud 115200 38400 9600 ttyAMA0 vt102
  639 ?        Ss     0:00 /lib/systemd/systemd --user
  644 ?        Sl     0:00 lightdm --session-child 13 16
  648 ?        S      0:00 (sd-pam)
  668 tty1     S+     0:00 -bash
  669 ?        Ssl    0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
  702 ?        Ss     0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session x-session-manager
  705 ?        S      0:00 /usr/bin/dbus-launch --exit-with-session x-session-manager
  706 ?        Ss     0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
  712 ?        Sl     0:00 /usr/lib/gvfs/gvfsd
  715 ?        S<     0:00 [kworker/0:1H]
  717 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
  723 ?        S<     0:00 [kworker/2:1H]
  728 ?        S      0:00 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
  730 ?        Sl     0:00 lxpolkit
  733 ?        Sl     0:01 lxpanel --profile LXDE-pi
  734 ?        Sl     0:00 pcmanfm --desktop --profile LXDE-pi
  741 ?        Ss     0:00 /usr/bin/ssh-agent -s
  746 ?        Ssl    0:00 /usr/lib/policykit-1/polkitd --no-debug
  753 ?        Sl     0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
  761 ?        Ssl    0:00 /usr/lib/udisks2/udisksd --no-debug
  772 ?        Sl     0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
  777 ?        Sl     0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
  781 ?        Sl     0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
  785 ?        Sl     0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
  792 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvfs/exec_spaw/0
  795 ?        Ssl    0:00 /usr/lib/menu-cache/menu-cached /tmp/.menu-cached-:0-pi
  810 ?        S      0:00 [jbd2/mmcblk0p3-]
  811 ?        S<     0:00 [ext4-rsv-conver]
  855 ?        S<     0:00 [kworker/1:1H]
  859 ?        S      0:00 [kworker/3:2]
  863 ?        Sl     0:00 lxterminal
  864 ?        S      0:00 gnome-pty-helper
  865 pts/0    Ss+    0:00 /bin/bash
  873 ?        Ss     0:00 sshd: pi [priv]
  886 ?        R      0:00 sshd: pi@pts/1
  889 pts/1    Ss     0:00 -bash
  902 pts/1    R+     0:00 ps ax
pi@raspberrypi ~ $
#4 2015-12-02 11:32:44
soxso2011
When I enter the ip address of my raspberry pi in the browser ( same address used for connecting with rexview and downloading the HMI) , It says " This webpage is not available"
             ERR_CONNECTION_REFUSED
#5 2015-12-03 01:49:32
You are running REX on Raspbian Jessie, which is not fully tested yet.
The problem is that the lighttpd webserver is not running on your Raspberry Pi. During installation you received an error which you probably overlooked.
See this topic for more details.
#6 2015-12-03 08:22:12
soxso2011
No, when I had typed sudo apt-get install rexwstcp lighttpd=1.4.31-103 lighttpd-mod-websocket, it says " lighttpd is already the newest version & lighttpd-mod-websocket is already the newest version."
Then anyways I had apt-get --purge removed lighttpd and reinstalled using "sudo apt-get install rexwstcp lighttpd=1.4.31-103 lighttpd-mod-websocket" as you said on the other topic. Then it worked fine for some time. Now after rebooting the raspberry while it was connected to the hmi, the same error in browser - connection refused.
Tried rebooting both my windows pc, raspberry, force reloaded lighttpd , downloaded the pool automation example to raspberry and tried again.
It is simply refusing to connect to HMI !!
#7 2015-12-03 16:32:34
You are right, that's because the lighttpd webserver does not start correctly after reboot. See the other topic again for a workaround.
