I would like to know if anyone has found a way to write values to the WST table of the WSCH block without doing so via RexDraw? I would like to be able to alter the weekly schedule via a web page.
Thanks in advance!
Chand
Hi Chand,
thanks for your question. Changing array parameters from a webpage is not possible in version 2.10.8. You are not the first one to ask for this feature, it will be available in the new version of REX, which is now being tested by our beta-testers.
You'll be notified when we release the new version.
I look forward to its release.
Thanks Jaroslav!
Is it now possible with 2.50.5 to adjust the array parameters from a HMI? If so, how do I do it?
Cheers,
Adam
Hi Adam,
yes, it is now possible to configure WSCH function block using HMI. See the example attached:
0201-24_WSCH_Week_Schedule_with_HMI.zip - edited link
If you experience any difficulties running the example I will be happy to help.
Thank you Tomas, your help is very much appreciated.
Adam
Hi Adam,
please use this example project: 0201-24_WSCH_Week_Schedule_with_HMI.zip
The one posted before will not work.
