#1 2016-08-26 17:04:39
ad_t
SQL query with variables
If I want to run the MSSQL query below to pull data from a database, but for example have 'room_id' and 'function_status_id' defined from within a task (i.e. have a CNI block within the task to assign room_id), is that possible, and if so how?
SELECT COUNT(*) as Occupied FROM ev_functions WHERE room_id = 6 and DATEADD(HOUR,-3,GETDATE()) > from_date_time and GETDATE() < to_date_time and function_status_id = 6
Cheers,
Adam
#2 2016-08-29 06:37:47
Re: SQL query with variables
Hi Adam,
very good question! This is not possible in the current version. The good news is that it is already implemented in the new version which we are finalizing.
#3 2016-08-30 18:20:08
ad_t
Are you able to give me rough idea on a timeline for the new version; i.e. weeks or months? It would be good to know whether I should use a workaround for now, or just wait till the new release?
Cheers,
Adam
#4 2016-09-02 11:04:44
Hi Adam,
it will be weeks. A single-digit number of weeks.
