Yes, your conf file is incorrect. The /etc/owfs.conf file should contain these 5 lines for use on the UniPi
!server: server = 127.0.0.1:4304
allow_other
server: port = 127.0.0.1:4304
server: i2c=ALL:ALL
timeout_volatile = 2
Comment or delete the other lines.
I have setup conf. file as above but no luck....
If I type in the owdir command nothing comes up.
also see below;
[FAIL] Restarting 1-Wire TCP Server: owserver failed! #####this is message from terminal
Did you enable the I2C bus in the /boot/config.txt file? Do you have i2c-dev in your /etc/modules file?
If you don't mind re-flashing your SD card, you might want to use the installation scripts which are available at
https://github.com/rexcontrols/rex-install-rpi
Start with fresh Wheezy image from 2015-05-05, expand the filesystem and follow the installation instructions in the readme.md file.
