#1 2016-04-05 13:14:25
Using vectors in REXLANG FB to increase number of outputs, possible?
I need more than 16 outputs in the REXLANG function block and I was wondering if I could multiplex all internal values into a vector and assign it to an output. Then a VTOR can be used to demultiplex the vector again into separate values......
If possible then what syntax should be used inside the REXLANG FB?
Maybe an example...? :-)
#2 2016-04-06 07:37:41
Re: Using vectors in REXLANG FB to increase number of outputs, possible?
Hey scoobsalamander,
thank you for your tricky question wink
Unfortunately, it is not possible to use a vector as a REXLANG output.
However it is possible to split range of all the outputs if you don't need the full 32b range. Therefore you can use up to 16x32b = 512 binary outputs with one REXLANG block smile
Please, see the basic example on how to pass two 16b numbers through one 32b REXLANG output:
REXLANG_MultiOutput.zip
Hope that it will solve your issue.
#3 2016-04-06 08:05:33
The problem is that I have +30 signals coming in from various wireless sensors (Jeenode) all over the house. These sensors are sending packages (RFM12B 868Mhz) to a monitoring node (Nanode RF)
This board uses the JeeUDP program (to be found in the Jeelib library) to send all received packages over ethernet (UDP) to my RasPi (REXcontrols)
I tried using multiple REXLANG function blocks but somehow only one is working, I guess it is not possible to use several REXLANG FB's who are listening to the same port for UDP packages.... This makes that I have now only one working block with only 16 outputs......
(in the future I might change over to a JeeLink which can be put directly onto one of the USB ports of the RasPi.....)
#4 2016-04-06 08:32:14
You are right that it is not possible to use more REXLANGs listening to the same port. Eventually, there is a workaround. You can use UDP communication between two REXLANGs on localhost (and with different listening port) and forward the data from "master" REXLANG (which is listening to your UDP port with JeeUDP) to the "slave" one.
Do you really need full 32b range for all the 16 outputs? The solution with more outputs "emulated" on one output signal would be much more convenient from my point of view.
#5 2016-04-06 08:40:03
....forgot to mention that all those signals are from the double type :-)
#6 2016-04-06 08:56:31
This master-slave thing could work...maybe I can sort  the incoming messages into different streams depending on their address/function with the switch-case functionality.....although I think at the end it will be better to buy the Jeelink and by-pass all this UDP stuff....but then I will need to use the REXLANG FB again for the serial communication and I will be stuck again with this bottleneck of 16 outputs.
#7 2016-04-06 09:41:54
In the new version of REX, it will be possible to write from REXLANG to parameters of other blocks (e.g. CNR, PARR, etc.) outside the REXLANG function block. So you will be able to operate with more than the native 16 outputs of REXLANG.
Beta version of the new release will be available soon smile
#8 2016-04-06 10:48:17
Nice to hear! Thanks for the support and for the constant developing......
#9 2016-04-06 23:45:40
The solution with the localhost UDP connection is working fine.
By means of a switch statement I'll check for the node address (which is a part of the received message) and if it is not assigned to that particular REXLANG FB then the buffer will be passed to the following block by an internal UDP link until the corresponding block is found where it will be send to the output.  (can be daisy chained....)
Thx for the hint.....
*   REXLANG  - data exchange via UDP protocol          *
*   (c) REX Controls, www.rexcontrols.com              *
#define CON_UDP      64         //internal constant for UDP communication
#define RECEIVER_IP  0xC0A8B236 //192.168.178.54 - REXControl RasPi
#define SENDER_IP    0xC0A8B21F //192.168.178.31 - Nanode RF (message relay board)
#define senderPort   23456
#define receiverPort 4001
#define nextRexlangPort 4003  //port on next rexlang block
#define BUFFER_SIZE  80    //maximum number of bytes to receive
//assigning variables to outputs
//SENSOR NODE 11 :
double output(0) signal0;    	//battery voltage
double output(1) signal1;    	//room temperature
double output(2) signal2;    	//room humidity
double output(3) signal3;  		//counter
//SENSOR NODE 12 :
double output(4) signal4;  		//battery voltage
double output(5) signal5;    	//room temperature
double output(6) signal6;    	//room humidity
double output(7) signal7;    	//counter
//SENSOR NODE 10 :
double output(8) signal8;  		//Power 1
double output(9) signal9;    	//Power 2
double output(10) signal10;    	//Power 3
double output(11) signal11;    	//Vrms
//SENSOR NODE 13 :
double output(12) signal12;  	//battery voltage
double output(13) signal13;    	//room temperature
double output(14) signal14;    	//room humidity
double output(15) signal15;	 	//counter
//declaration of variables
long hRecvLoc;             //socket handle
long buffer[BUFFER_SIZE];  //buffer for incoming data
long dataCnt;              //number of received bytes
long sendDataCnt;
long convData[2];          //array for data conversions
double node;
long hSendLoc;
long sendBuffer(long rexlangPort)
	if (hSendLoc<0)
    hSendLoc = Open(CON_UDP,0x7F000001,4002,0x7F000001,rexlangPort);  //opening UDP socket- localhost
  else
	  sendDataCnt = Send(hSendLoc,buffer,BUFFER_SIZE); //send data
	  signal6 = hSendLoc;
	 return 0;
/* Initialization of the REXLANG algorithm */
// the init procedure is executed once when the REXLANG function block initializes
long init(void)
  hRecvLoc = -1;
  hSendLoc = -1;
  dataCnt = 0;
  sendDataCnt = 0;
	return 0;
/* The body of REXLANG algorithm */
// the main procedure is executed once in each sampling period
long main(void)
  long i;
  if (hRecvLoc<0)
    hRecvLoc = Open(CON_UDP,RECEIVER_IP,receiverPort,SENDER_IP,senderPort);  //opening UDP socket
  else
    //receive the data
    dataCnt = Recv(hRecvLoc,buffer,BUFFER_SIZE); //receive data, max number of bytes = BUFFER_SIZE
	node = (((buffer[43]-48)*10)+((buffer[44]-48))); //node number is in ASCII format
	//signal3 = node;
    switch(node)
		case 11: //Node 11
		signal0 = buffer[60] ; //Battery voltage
		signal0 = signal0/100;
		signal1 = buffer[58]<<16 | buffer[59]<<24; //Room temperature SHT22
		signal1 = signal1/1048576; //divide by (256*256*100)
		//signal2 = not used
		signal3 = buffer[54] | buffer[55]<<8 | buffer[56]<<16 | buffer[57]<<24; //Message counter
		break;
		case 12: //Node 12
		signal4 = buffer[60] ; //Battery voltage
		signal4 = signal4/100;
		signal5 = buffer[58]<<16 | buffer[59]<<24; //Room temperature SHT22
		signal5 = signal5/1048576; //divide by (256*256*100)
		//signal6 = not used
		signal7 = buffer[54] | buffer[55]<<8 | buffer[56]<<16 | buffer[57]<<24; //Message counter
		break;
		case 13: //Node 13
		signal12 = buffer[63] ; //Battery voltage
		signal12 = signal12/100;
		signal13 = buffer[59]<<16 | buffer[60]<<24; //Room temperature SHT22
		signal13 = signal13/6553600; //divide by (256*256*100)
		signal14 = buffer[61]<<16 | buffer[62]<<24; //Room humidity SHT22
		signal14 = signal14/6553600; //divide by (256*256*100)
		signal15 = buffer[55] | buffer[56]<<8 | buffer[57]<<16 | buffer[58]<<24; //Message counter
		break;
		case 10: //Node 10
		signal8 = buffer[55]<<16 | buffer[56]<<24;				//Power 1
		signal8 = signal8/65536; //divide by (256*256)
		signal9 = buffer[57]<<16 | buffer[58]<<24;				//Power 2
		signal9 = signal9/65536; //divide by (256*256)
		signal10 = buffer[59]<<16 | buffer[60]<<24;				//Power 3
		signal10 = signal10/65536; //divide by (256*256)
		signal11 = buffer[61]<<16 | buffer[62]<<24;				//Vrms
		signal11 = signal11/6553600; //divide by (256*256*100)
		break;
		default:
		sendBuffer(nextRexlangPort);
  return 0;
/* Closing the REXLANG algorithm */
long exit(void)
	if(hRecvLoc>=0) Close(hRecvLoc);
  return 0;
#10 2016-04-07 08:56:21
Good to hear!
Thank you for your feedback and sharing your code. Nice piece of work wink
