#1 2016-04-03 17:55:01
sudhir
Firing up the html on Windows 8.1 Laptop
I was able to run the simple PID loop example. The numbers change so it is running. I could not run the html. I get connection refused for the WS calls.
Do I need to install IIS8 or the light webserver? How do I configure those on my laptop so that the WS rex invocation goes through.
Thanks.
#2 2016-04-04 08:59:52
Re: Firing up the html on Windows 8.1 Laptop
Did you try to execute the "run.bat" script located in ./REX_2_10_xxxxxx/EXAMPLES/REX_TUTOR_PIDU/?
If you didn't succeed you can run it manually as follows:
1. Open "exec.mdl" in RexDraw, Compile and download (F6) (make sure to check "Start local RexCore if necessary" and also uncheck "Save the new configuration permanently" - if you don't have Administrator rights).
2. Open RexView and download HMI to target: Target / PC --> Target device...
3. Run RexHMI services (shortcut in Start menu Rex Controls folder)
4. Open web browser and fill in address 127.0.0.1:8008 and you should see the visualisation.
Hope it will help you.
#3 2016-04-10 17:00:33
sudhir
Thanks. That worked. Just got one error as shown in the following paragraph but rest seems to be working.
Appreciate your help.
C:\Program Files (x86)\REX Controls\REX_2_10_8_5910_x86\EXAMPLES\REX_TUTOR\PIDU>
run.bat
Downloading example to local rexcore..
Starting HMI..
Starting lighttpd web server ..
      1 [main] lighttpd 10000 find_fast_cwd: WARNING: Couldn't compute FAST_CWD
pointer.  Please report this problem to
the public mailing list cygwin@cygwin.com
Waiting few seconds..
Starting websocket backend..
Deleting C:\ProgramData\REX Controls\REX_2_10_8_5910\HMI
Downloading HMI from folder C:\Program Files (x86)\REX Controls\REX_2_10_8_5910_
x86\EXAMPLES\REX_TUTOR\PIDU\hmi
56 File(s) copied
Starting Web browser (http://127.0.0.1:8008/)..
Done. You should see HMI interface in your web browser now.
Press any key to continue . . .
#4 2016-04-10 17:11:23
sudhir
The Cygwin problem is caused by Windows 8.1 based on my Google research. The solution appears to be "use minGW instead Cygwin" for the compile process.
#5 2016-04-11 08:07:54
Hello sudhir,
thank you very much for your suggestions! I will forward it to a person who is responsible for HMI.
Have a nice day, Tomas
