#1 2016-03-18 12:07:22
matthijs
problem with 1-wire sensors and sensors connected by SILO
Error which become visible every ~3 hours:
FluxBB bbcode test
The SILO blocks stop for no reason:
FluxBB bbcode test
But that does not happen all at once:
FluxBB bbcode test
What goes wrong?
REX-programm.zip
With kind regards,
Matthijs
#2 2016-03-19 07:49:21
Re: problem with 1-wire sensors and sensors connected by SILO
Thanks for reporting this. Is there any error displayed at the outputs of the SILO blocks? Did you check the contents of the input files? Is it changing? Can you change the value in the input file manually? I'm just trying to locate the problem...
As for the errors of the 1-Wire I/O driver, there is nothing to worry about. The 1-Wire bus is by design not reliable, therefore some communication errors do occur. The log messages are confusing, I agree. This I/O driver is in the hands of our developers at the moment and the system log messages are one of the improvements.
