Hi , I noticed that the Rexlang block freezes due to an illegal operation then refuses to reset. In my program , I had put in a line
output_y0= input_1/input_2.
When the program is first downloaded , Input_2 is '0' because input_2 has to be manually entered from HMI. So after the program is downloaded, The rexlang block does not produce output_y0 .On checking rexview, the iE code says error - division by zero. Later, even when a positive value is entered from HMI, it still does not produce output_y0. The issue has been solved with a bit of if, else logic as in if in input_2 is zero , Output_y0= some initial constant value.
Im not sure if this is a bug or it is intentional, just thought id share it on the forum. Thanks !
Thanks for posting your findings. This is a feature in versions <=2.10.x, not a bug. In future versions the REXLANG block will have a RESET input.
