Hi
How to use(or define) the virtual axis in the RexCore ?
from Rex point of view every axis (function block RM_Axis) you add into your .mdl task is meant to be virtual. As soon as you connect the axis to the "real world" (controller) you can call it physical axis. There is no differentiation between virtual and physical axis in the Rex control system.
