Hi
I have see this block in your example. Cloud you tell me how to create it int the RexDraw ?
It is a Subsystem block. Find it in the drawing or function block library, select it and press F1 for help.
Or you can choose the function blocks which are supposed to be inside the Subsytem (left click and move) and press Ctrl+G "Create Subsytem". It will automatically create the subsystem with all the inputs and outputs - then you can just delete unused I/Os.
