#1 2016-02-26 08:45:21
jinyistudio
Website
User defined Tag(variable)
Hi
How to define user tag(bit or word in the RexDraw ?
#2 2016-02-26 14:32:51
Re: User defined Tag(variable)
if you need global variable try to use "CNR" (real), "CNI" (integer) or "CNB" (bool) connected to "GoTo" block. Be sure to specify TagVisibility parameter inside "GoTo" flag as "global". Then add "From" flag and specify the same GotoTag parameter. This approach works within .mdl file.
For connections between different .mdl files see documentation for "Inport" and "Outport".
