Hi
Could you tell me what is "Arbitrary script executable on the Raspberry Pi
arbitrary script means that it can be a shell script (on Windows this would be a batch file), a Python script or a script in any other language (e.g. PHP).
You can e.g. read some sensor value using e.g. a Python script and then pass the value to the control algorithm. Or you can have some control algorithm in REXYGEN and pass its output to a script which will execute the necessary actions.
It is also possible to combine this approach with use of REST API - for more details see: User manual REST API of REXYGEN
If you require more information, do not hesitate to contact me.
