#1 2018-12-21 18:17:02
martin.schrewe
WSCH-Block in Subsystems
in my project I've several WSCH-blocks with surrounding logic, that i want to put into a subsystem. But i haven't found  a way to export the WSCH-arrays as a parameter of the subsystem. If it's not possible up to now, i would like to place it as a feature request here.
Martin
#2 2018-12-22 11:36:04
Re: WSCH-Block in Subsystems
Hello Martin,
we are aware that the integration of WSCH into project is far from perfect. However it is possible to get/set WSCH arrays remotely. Have a look at function blocks called SETPX and GETPX (where X is a type - A=array, R=real, ...).
There is also one example which might help you - try out example "0201-24_WSCH_Week_Schedule_with_HMI".
If you have any doubts, just let us know.
