After searching the online manual to find a function block that would allow me to create a "Pull-up" or "Pull-down" switch for use with the raspberry pi gpio pins, any suggestions?
I am using a CNB" function tied to a "GOTO" referencing the GPIO I am pulling low and it is responding but do want to make certain this is the correct way to do so.
Thank you.
Hi tazntex,
your approach is absolutely perfect. Did you go through the Getting started guide for REXYGEN on Raspberry Pi? I believe namely the chapter 5 answers your questions.
