#1 2018-10-06 23:05:53
mikeyh
Max and Min of gauges/display in HMI Designer
Hi All,
I'm after away of making the Max and Min of a gauge or display a delta, rather than an absolute.
Within the gauge options in the HMI designer you can set Max and Min, e.g. -50....50°C. This gives you option to change colour if outside of these limits, red for above and blue for below etc. But the value is absolute, not relative to anything. What I want to do is set the Max and Min as a delta from say a CNR block (set point block). This lets me change colour if say the value is 2 degrees above or below what the CNR block is set to.
Thanks in advance
Mike
#2 2018-10-10 17:12:07
Re: Max and Min of gauges/display in HMI Designer
Hi Mike,
it is not possible to have relative limits inside the components.
However for display component there is a workaround with color animation. For more details have a look at example "0301 - 08 HMI Animation DEMO" which is part of installation. It will give you an idea how to use various animations in REXYGEN HMI Designer.
Let us know about your progress.
#3 2018-10-11 06:12:06
mikeyh
Thank you Tomas, I will let you know what I end up doing.
Cheers
Mike
