Hello there,
is there a simple and convenient way to make multiple HMI interfaces for one project?
Eg. I would like to have an access for auto-generated WebWatch witch is very useful, and at the same time work on InkScape project (rexygen hmi designer).
To be honest i didn't tried it, but I suppose that, when I copy files generated by Inkscape and select to auto gen the WebWatch files it will overwrite inkscape files, right?
Hello Hubert,
thank you for your question. There is example "0301-07 Multi-page HMI" available via REXYGEN Studio which shows how to combine Inkscape based HMI (.svg) with RexHMI (WebBuDi = .js). In similar way you can combine Inkscape based HMI with WebWatch as you wanted. I recommend you to give it a try and have a look at:
files inside "hmisrc" directory - naming is important!
HMI function block setup in REXYGEN Studio - for WebWatch also tick "GenerateWebWatch"
any .svg file in "hmisrc" directory - read the instructions given at the bottom of the page and investigate how creating links works
any .js file in "hmisrc" directory
The overwriting can occur only if the Inkscape HMI file names would be the same as .mdl file names (e.g. myproject_task.hmi.svg vs myproject_task.mdl) - but I see no point in mixing the names in this way
If you run into any troubles, let me know.
