Hi Rexygen team,
I'd like to make use of the PIDGS – PID controller with gain scheduling function block and was wondering if you had any sample projects implementing it which you could share?
Chand
Hi Chand,
please have a look at the example for PIDU block (0201-22). Once you understand the PIDU block, using the PIDGS should be relatively easy. I believe the documentation of PIDGS block explains quite clearly what the block does and how to use it.
If you have any particular question regarding the PIDGS block, just let me know.
