#1 2018-04-06 11:09:14
bodie
REXLANG measure duration of code execution
ïs it possible somehow to measure, how long the code inside REXLANG is running each periode? I tried using functions CurrentTime and ElapsedTime, but this is not working.
Thanks for help.
example:
long main(void)
	time_start = CurrentTime();
        /*EXECUTED CODE*/
	time_out = ElapsedTime(CurrentTime(),time1);
	return 0;
#2 2018-04-06 11:17:52
Re: REXLANG measure duration of code execution
Hello bodie,
your approach is completely right - I would do it the same way.
The issue is that you are referencing wrong variable into ElapsedTime() function. It should look like:
long main(void)
        /*EXECUTED CODE*/
	time_out = ElapsedTime(CurrentTime(),time_start);
	return 0;
Hope it helps.
#3 2018-04-06 12:11:43
bodie
it is my mistake, I do not change the name of both variables in the post, in the REXLANG code it is OK. Problem is that the time_out is zero. I checked value time_start in Trace (or CurrentTime from each periode, see code below) and it is not changing for several periodes. The periode of task is 2 ms. I do not know what is the resolution of ElapsedTime function?
The data type of time1 variable is double.
long init(void)
	time1 = CurrentTime();
	return 0;
long main(void)
	Trace(11,CurrentTime()-time1);
	return 0;
6.4.2018    13:07:41.009    Info    REXLANG[00289,00029,0011]: 7052
6.4.2018    13:07:41.011    Info    REXLANG[00289,00029,0011]: 7052
6.4.2018    13:07:41.013    Info    REXLANG[00289,00029,0011]: 7052
6.4.2018    13:07:41.015    Info    REXLANG[00289,00029,0011]: 7067
6.4.2018    13:07:41.017    Info    REXLANG[00289,00029,0011]: 7067
6.4.2018    13:07:41.019    Info    REXLANG[00289,00029,0011]: 7067
6.4.2018    13:07:41.021    Info    REXLANG[00289,00029,0011]: 7067
6.4.2018    13:07:41.023    Info    REXLANG[00289,00029,0011]: 7067
6.4.2018    13:07:41.025    Info    REXLANG[00289,00029,0011]: 7067
6.4.2018    13:07:41.027    Info    REXLANG[00289,00029,0011]: 7067
6.4.2018    13:07:41.029    Info    REXLANG[00289,00029,0011]: 7083
6.4.2018    13:07:41.031    Info    REXLANG[00289,00029,0011]: 7083
6.4.2018    13:07:41.033    Info    REXLANG[00289,00029,0011]: 7083
6.4.2018    13:07:41.035    Info    REXLANG[00289,00029,0011]: 7083
#4 2018-04-09 15:49:38
Hi bodie,
are you sure the time1 variable is of type double? I guess it's a long in your declaration.
Let me know,
#5 2018-04-10 08:41:17
bodie
the declaration looks like this:
double time1 = 0;
I tried using
double time1 = 0.0;
to see if the type is not cast to long, but it did not help.
I tried several things and now it is working - the code is OK, but I was running it on localhost on PC. When I download it to RPi3 and run, it is OK.
So only for be sure, is there problem running some functions on PC, or probably is it some kind of bug?
#6 2018-04-10 09:40:16
Hello Bodie,
sorry for troubles with platform inconsistency. You are right - on Linux based systems it works well - however you should be aware that ElapsedTime() returns value in microseconds (Linux) / miliseconds (Windows).
Many thanks for reporting this bug. We will fix it in next release.
If I can be of any assistance, let me know.
#7 2018-04-10 09:46:28
bodie
Thanks for informations and your help.
