Hi all,
I have been pulling my hair out over the past week. On 04MAY2017 we had a nasty storm in the area that caused power outages due to high winds, no lightening. Later that evening I was alerted that the Raspberry Pi II controller was no longer working. After diagnostics I found that the updates database was corrupt and I also think I seen rex updates in this. I was able to clean the database and install updates but I did not see the rex updates again. Looking at rex logs, the only fault I found was (rpidrv - unable to get rpi version, assuming v1). I figured something was corrupted on SD card so I wiped media clean and installed freshly downloaded image of Rasp, Jess Lite. After install updates and rex core installation I am still having same issues, no GPIO access.
Felt like at this point I lost GPIO controller, so I fired up beta Pi III unit, with fresh install of same image, updates, and rex-core install. same results completely different Raspberry Pi unit that has been powered down since ??FEB2017.
Did an update kill rpidrv? or am I just completely missing something? I have not seen anyone else post any of the same issues, so I think I am just missing something. I have run my code and demo advanced pool code with same results. The code that was running was running flawless since about ??DEC2016 until now.
Any help or advice will be much appreciated.
Hi gizmo,
I'm sorry to hear about your troubles. It always hurts to know that somebody is pulling his hair out while using our software...
Installing a fresh Raspbian Jessie was certainly a good idea (just to make sure: image date 2017-04-10?).
Can you please post here the output of
apt-cache show rexcore
apt-cache show rex-rpidrvtYou should have version 2.50.1 installed.
GPIO access should be possible, we have by no means removed that.
Thanks for reporting this problem, I'll do my best to get you up and running soon.
jaroslav_sobota,
Sorry,
I think it is really on my end, I am easy going and not upset. Just not adding up why all of a sudden I am getting the issues that I am. I know your team is very quick and to the point in resolving issues, I just wanted to exhaust, and eliminate issues on my side before I posted for help. I really was hoping it was something simple and could post about my experience that could possible help others.
Thanks again,
pi@VAS-TEST:~ $ apt-cache show rexcore
Package: rexcore
Version: 2.50.1-7567~Debian~jessie
Architecture: armhf
Conflicts: rexcore-xeno
Recommends: rex-webfiles (= 2.50.1-7567~Debian~jessie),rex-dochtml (= 2.50.1-7567~Debian~jessie),rex-docpdf (= 2.50.1-7567~Debian~jessie)
Maintainer: Roman Pisl, REX Controls s.r.o. <pisl@rexcontrols.cz>
Priority: optional
Section: admin
Filename: pool/non-free/r/rexcore/rexcore_2.50.1-7567~Debian~jessie_armhf.deb
SHA256: 879824c03be942ced1bb659c8f6b1d6628939482880f20d0f0e8bf343c7cb520
SHA1: 55a4f3f8498375f1f25d106e789e9db1a7aec962
MD5sum: 5bf9fc364787aacd0b9961cd18f485c6
Description: REX Control System core
Real-time core of the REX Control System for advanced process control
Linux soft RT version
Description-md5: 2834ec595b112fe8908077497bd1c74c
pi@VAS-TEST:~ $ apt-cache show rex-rpidrvt
Package: rex-rpidrvt
Architecture: armhf
Depends: rexcore (= 2.50.1-7567~Debian~jessie)
Priority: optional
Section: admin
Filename: pool/non-free/r/rex-rpidrvt/rex-rpidrvt_2.50.1-7567~Debian~jessie_armhf.deb
SHA256: c8d8b6678b2cba07c157d76b6c2312301a8a8b531f73b3cb5b687142c8ccdc50
SHA1: a336d8e96211759e2849c119743112bb4c20b603
MD5sum: 752ab6fe7f9b3e13cdb07802580fdab6
Description: REX driver for Raspberry Pi
Raspberry Pi driver for the REX Control System
Description-md5: a9169f5669b5458f135b7ef6067b591f
Hi gizmo,
no need to apologize. In your place, I would be confused as well...
Thanks for the update. I do not see any problem, you have version 2.50.1 installed correctly.
I double checked this on RPi B+, RPi 2 and RPi 3 and everything seems to be working on my testing devices. You mentioned an error "rpidrv - unable to get rpi version, assuming v1" and that might be a lead, because on my devices the RPi version is always detected correctly.
Are you using off-the-shelf RPi 2 and RPi 3? No compute module or anything like that, right? What date was the Raspbian Jessie Lite image you are using released? 2017-04-10?
Can you please post here the output of the following commands on both your devices?
uname -a
cat /etc/*-release
cat /proc/cpuinfo
lscpuThanks again,
Sorry for the delay, stuck at work for the last few.
pi@VAS-TEST:~ $ uname -a
Linux VAS-TEST 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Li
pi@VAS-TEST:~ $ cat /etc/*-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@VAS-TEST:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2835
Revision : a22082
Serial : 00000000ac96d278
pi@VAS-TEST:~ $ lscpu
Architecture: armv7l
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Model name: ARMv7 Processor rev 4 (v7l)
CPU max MHz: 1200.0000
CPU min MHz: 600.0000
Hi gizmo,
thanks for the information. This is from your RPi3. Any chance you could also run that on your RPi2? Thanks!
Working Condition
Raspberry Pi 2, 2017-04-10-raspbian-jessie-lite, no updates, no raspi-config, installed GIT, cloned https://github.com/rexcontrols/rex-install-rpi.git --branch v2.50, Rex Core installed via, bash install-rex.sh.
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
pi@raspberrypi:~ $
pi@raspberrypi:~ $ cat /etc/*-release
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
pi@raspberrypi:~ $
pi@raspberrypi:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 5 (v7l)
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
Hardware : BCM2709
Revision : a21041
Serial : 000000002b2fe94f
pi@raspberrypi:~ $
pi@raspberrypi:~ $ lscpu
CPU(s): 4
Socket(s): 1
Model name: ARMv7 Processor rev 5 (v7l)
CPU max MHz: 900.0000
pi@raspberrypi:~ $
Not in Rec logs.
UPGRADE package
pi@raspberrypi:~ $ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
binutils ca-certificates initramfs-tools libc-bin libc-dev-bin libc6 libc6-dbg libc6-dev libgnutls-deb0-28 libgnutls-openssl27 libicu52 libldap-2.4-2
libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 libsystemd0 libtirpc1 libudev1 locales multiarch-support raspberrypi-bootloader
raspberrypi-kernel raspi-config rpcbind systemd systemd-sysv tzdata udev unzip vim-common vim-tiny wget
33 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 98.3 MB of archives.
After this operation, 4,490 kB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi-dev armhf 1.20170427-1 [401 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc6-dev armhf 2.19-18+deb8u9 [1,724 kB]
Get:3 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi-doc armhf 1.20170427-1 [31.4 MB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-dev-bin armhf 2.19-18+deb8u9 [231 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc6-dbg armhf 2.19-18+deb8u9 [3,178 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtirpc1 armhf 0.2.5-1+deb8u1 [69.2 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ jessie/main rpcbind armhf 0.2.1-6+deb8u2 [37.7 kB]
Get:8 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-bin armhf 2.19-18+deb8u9 [1,206 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc6 armhf 2.19-18+deb8u9 [4,082 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ jessie/main libudev1 armhf 215-17+deb8u7 [53.6 kB]
Get:11 http://mirrordirector.raspbian.org/raspbian/ jessie/main udev armhf 215-17+deb8u7 [850 kB]
Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main libicu52 armhf 52.1-8+deb8u5 [6,554 kB]
Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main initramfs-tools all 0.120+deb8u3 [96.7 kB]
Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main libsystemd0 armhf 215-17+deb8u7 [85.8 kB]
Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd armhf 215-17+deb8u7 [2,216 kB]
Get:16 http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd-sysv armhf 215-17+deb8u7 [36.7 kB]
Get:17 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnutls-openssl27 armhf 3.3.8-6+deb8u5 [140 kB]
Get:18 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnutls-deb0-28 armhf 3.3.8-6+deb8u5 [626 kB]
Get:19 http://mirrordirector.raspbian.org/raspbian/ jessie/main libldap-2.4-2 armhf 2.4.40+dfsg-1+deb8u2 [192 kB]
Get:20 http://mirrordirector.raspbian.org/raspbian/ jessie/main tzdata all 2017b-0+deb8u1 [232 kB]
Get:21 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim-tiny armhf 2:7.4.488-7+deb8u3 [357 kB]
Get:22 http://mirrordirector.raspbian.org/raspbian/ jessie/main multiarch-support armhf 2.19-18+deb8u9 [181 kB]
Get:23 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim-common armhf 2:7.4.488-7+deb8u3 [185 kB]
Get:24 http://mirrordirector.raspbian.org/raspbian/ jessie/main wget armhf 1.16-1+deb8u2 [475 kB]
Get:25 http://mirrordirector.raspbian.org/raspbian/ jessie/main locales all 2.19-18+deb8u9 [3,937 kB]
Get:26 http://mirrordirector.raspbian.org/raspbian/ jessie/main binutils armhf 2.25-5+deb8u1 [3,470 kB]
Get:27 http://mirrordirector.raspbian.org/raspbian/ jessie/main ca-certificates all 20141019+deb8u3 [207 kB]
Get:28 http://mirrordirector.raspbian.org/raspbian/ jessie/main unzip armhf 6.0-16+deb8u3 [142 kB]
Get:29 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-kernel armhf 1.20170427-1 [31.5 MB]
Get:30 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi-bin armhf 1.20170427-1 [334 kB]
Get:31 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi0 armhf 1.20170427-1 [844 kB]
Get:32 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-bootloader armhf 1.20170427-1 [3,303 kB]
Get:33 http://archive.raspberrypi.org/debian/ jessie/main raspi-config all 20170503 [18.8 kB]
Fetched 98.3 MB in 35s (2,775 kB/s)
Reading changelogs... Done
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 34407 files and directories currently installed.)
Preparing to unpack .../libc6-dev_2.19-18+deb8u9_armhf.deb ...
Unpacking libc6-dev:armhf (2.19-18+deb8u9) over (2.19-18+deb8u7) ...
Preparing to unpack .../libc-dev-bin_2.19-18+deb8u9_armhf.deb ...
Unpacking libc-dev-bin (2.19-18+deb8u9) over (2.19-18+deb8u7) ...
Preparing to unpack .../libc6-dbg_2.19-18+deb8u9_armhf.deb ...
Unpacking libc6-dbg:armhf (2.19-18+deb8u9) over (2.19-18+deb8u7) ...
Preparing to unpack .../libtirpc1_0.2.5-1+deb8u1_armhf.deb ...
Unpacking libtirpc1:armhf (0.2.5-1+deb8u1) over (0.2.5-1) ...
Preparing to unpack .../rpcbind_0.2.1-6+deb8u2_armhf.deb ...
Unpacking rpcbind (0.2.1-6+deb8u2) over (0.2.1-6+deb8u1) ...
Preparing to unpack .../libc-bin_2.19-18+deb8u9_armhf.deb ...
Unpacking libc-bin (2.19-18+deb8u9) over (2.19-18+deb8u7) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u6) ...
Setting up libc-bin (2.19-18+deb8u9) ...
Preparing to unpack .../libc6_2.19-18+deb8u9_armhf.deb ...
Unpacking libc6:armhf (2.19-18+deb8u9) over (2.19-18+deb8u7) ...
Setting up libc6:armhf (2.19-18+deb8u9) ...
Processing triggers for libc-bin (2.19-18+deb8u9) ...
Preparing to unpack .../libudev1_215-17+deb8u7_armhf.deb ...
Unpacking libudev1:armhf (215-17+deb8u7) over (215-17+deb8u6) ...
Setting up libudev1:armhf (215-17+deb8u7) ...
Preparing to unpack .../udev_215-17+deb8u7_armhf.deb ...
Unpacking udev (215-17+deb8u7) over (215-17+deb8u6) ...
Setting up udev (215-17+deb8u7) ...
addgroup: The group `input' already exists as a system group. Exiting.
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.120+deb8u2) ...
Preparing to unpack .../initramfs-tools_0.120+deb8u3_all.deb ...
Unpacking initramfs-tools (0.120+deb8u3) over (0.120+deb8u2) ...
Preparing to unpack .../libsystemd0_215-17+deb8u7_armhf.deb ...
Unpacking libsystemd0:armhf (215-17+deb8u7) over (215-17+deb8u6) ...
Setting up libsystemd0:armhf (215-17+deb8u7) ...
Preparing to unpack .../systemd_215-17+deb8u7_armhf.deb ...
Unpacking systemd (215-17+deb8u7) over (215-17+deb8u6) ...
Processing triggers for dbus (1.8.22-0+deb8u1) ...
Setting up systemd (215-17+deb8u7) ...
addgroup: The group `systemd-journal' already exists as a system group. Exiting.
Preparing to unpack .../systemd-sysv_215-17+deb8u7_armhf.deb ...
Unpacking systemd-sysv (215-17+deb8u7) over (215-17+deb8u6) ...
Setting up systemd-sysv (215-17+deb8u7) ...
Preparing to unpack .../libgnutls-openssl27_3.3.8-6+deb8u5_armhf.deb ...
Unpacking libgnutls-openssl27:armhf (3.3.8-6+deb8u5) over (3.3.8-6+deb8u4) ...
Preparing to unpack .../libgnutls-deb0-28_3.3.8-6+deb8u5_armhf.deb ...
Unpacking libgnutls-deb0-28:armhf (3.3.8-6+deb8u5) over (3.3.8-6+deb8u4) ...
Preparing to unpack .../libldap-2.4-2_2.4.40+dfsg-1+deb8u2_armhf.deb ...
Unpacking libldap-2.4-2:armhf (2.4.40+dfsg-1+deb8u2) over (2.4.40+dfsg-1) ...
Preparing to unpack .../libicu52_52.1-8+deb8u5_armhf.deb ...
Unpacking libicu52:armhf (52.1-8+deb8u5) over (52.1-8+deb8u4) ...
Preparing to unpack .../multiarch-support_2.19-18+deb8u9_armhf.deb ...
Unpacking multiarch-support (2.19-18+deb8u9) over (2.19-18+deb8u7) ...
Setting up multiarch-support (2.19-18+deb8u9) ...
Preparing to unpack .../tzdata_2017b-0+deb8u1_all.deb ...
Unpacking tzdata (2017b-0+deb8u1) over (2016j-0+deb8u1) ...
Setting up tzdata (2017b-0+deb8u1) ...
Current default time zone: 'Etc/UTC'
Local time is now: Wed May 17 01:21:46 UTC 2017.
Universal Time is now: Wed May 17 01:21:46 UTC 2017.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
(Reading database ... 34410 files and directories currently installed.)
Preparing to unpack .../vim-tiny_2%3a7.4.488-7+deb8u3_armhf.deb ...
Unpacking vim-tiny (2:7.4.488-7+deb8u3) over (2:7.4.488-7+deb8u2) ...
Preparing to unpack .../vim-common_2%3a7.4.488-7+deb8u3_armhf.deb ...
Unpacking vim-common (2:7.4.488-7+deb8u3) over (2:7.4.488-7+deb8u2) ...
Preparing to unpack .../wget_1.16-1+deb8u2_armhf.deb ...
Unpacking wget (1.16-1+deb8u2) over (1.16-1+deb8u1) ...
Preparing to unpack .../locales_2.19-18+deb8u9_all.deb ...
Unpacking locales (2.19-18+deb8u9) over (2.19-18+deb8u7) ...
Preparing to unpack .../binutils_2.25-5+deb8u1_armhf.deb ...
Unpacking binutils (2.25-5+deb8u1) over (2.25-5) ...
Preparing to unpack .../ca-certificates_20141019+deb8u3_all.deb ...
Unpacking ca-certificates (20141019+deb8u3) over (20141019+deb8u2) ...
Preparing to unpack .../unzip_6.0-16+deb8u3_armhf.deb ...
Unpacking unzip (6.0-16+deb8u3) over (6.0-16+deb8u2) ...
Preparing to unpack .../libraspberrypi-dev_1.20170427-1_armhf.deb ...
Unpacking libraspberrypi-dev (1.20170427-1) over (1.20170405-1) ...
Preparing to unpack .../libraspberrypi-doc_1.20170427-1_armhf.deb ...
Unpacking libraspberrypi-doc (1.20170427-1) over (1.20170405-1) ...
Preparing to unpack .../raspberrypi-kernel_1.20170427-1_armhf.deb ...
Adding 'diversion of /boot/bcm2708-rpi-0-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-0-w.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
Adding 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Adding 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/bmp085_i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/bmp085_i2c-sensor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c0-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c0-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c1-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c1-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/lirc-rpi.dtbo to /usr/share/rpikernelhack/overlays/lirc-rpi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-act-led.dtbo to /usr/share/rpikernelhack/overlays/pi3-act-led.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-disable-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-wifi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-miniuart-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/raspidac3.dtbo to /usr/share/rpikernelhack/overlays/raspidac3.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/rpi-cirrus-wm5102.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-dac.dtbo to /usr/share/rpikernelhack/overlays/rpi-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-display.dtbo to /usr/share/rpikernelhack/overlays/rpi-display.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-proto.dtbo to /usr/share/rpikernelhack/overlays/rpi-proto.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio-1bit.dtbo to /usr/share/rpikernelhack/overlays/sdio-1bit.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdtweak.dtbo to /usr/share/rpikernelhack/overlays/sdtweak.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-hw-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-hw-cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Unpacking raspberrypi-kernel (1.20170427-1) over (1.20170405-1) ...
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.50+ /boot/kernel.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.50-v7+ /boot/kernel7.img
Preparing to unpack .../libraspberrypi-bin_1.20170427-1_armhf.deb ...
Unpacking libraspberrypi-bin (1.20170427-1) over (1.20170405-1) ...
Preparing to unpack .../libraspberrypi0_1.20170427-1_armhf.deb ...
Unpacking libraspberrypi0 (1.20170427-1) over (1.20170405-1) ...
Preparing to unpack .../raspberrypi-bootloader_1.20170427-1_armhf.deb ...
Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Unpacking raspberrypi-bootloader (1.20170427-1) over (1.20170405-1) ...
Preparing to unpack .../raspi-config_20170503_all.deb ...
Unpacking raspi-config (20170503) over (20170307) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for install-info (5.2.0.dfsg.1-6) ...
Processing triggers for systemd (215-17+deb8u7) ...
Setting up libc-dev-bin (2.19-18+deb8u9) ...
Setting up libc6-dev:armhf (2.19-18+deb8u9) ...
Setting up libc6-dbg:armhf (2.19-18+deb8u9) ...
Setting up libtirpc1:armhf (0.2.5-1+deb8u1) ...
Setting up rpcbind (0.2.1-6+deb8u2) ...
insserv: warning: current start runlevel(s) (empty) of script `rpcbind' overrides LSB defaults (S).
insserv: warning: current stop runlevel(s) (0 1 6 S) of script `rpcbind' overrides LSB defaults (0 1 6).
Setting up initramfs-tools (0.120+deb8u3) ...
Setting up libgnutls-deb0-28:armhf (3.3.8-6+deb8u5) ...
Setting up libgnutls-openssl27:armhf (3.3.8-6+deb8u5) ...
Setting up libldap-2.4-2:armhf (2.4.40+dfsg-1+deb8u2) ...
Setting up libicu52:armhf (52.1-8+deb8u5) ...
Setting up vim-common (2:7.4.488-7+deb8u3) ...
Setting up vim-tiny (2:7.4.488-7+deb8u3) ...
Setting up wget (1.16-1+deb8u2) ...
Setting up locales (2.19-18+deb8u9) ...
Generating locales (this might take a while)...
en_GB.UTF-8... done
Generation complete.
Setting up binutils (2.25-5+deb8u1) ...
Setting up ca-certificates (20141019+deb8u3) ...
Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done.
Setting up unzip (6.0-16+deb8u3) ...
Setting up raspberrypi-bootloader (1.20170427-1) ...
Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Setting up libraspberrypi0 (1.20170427-1) ...
Setting up libraspberrypi-dev (1.20170427-1) ...
Setting up libraspberrypi-doc (1.20170427-1) ...
Setting up raspberrypi-kernel (1.20170427-1) ...
Removing 'diversion of /boot/bcm2708-rpi-0-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-0-w.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
Removing 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Removing 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/bmp085_i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/bmp085_i2c-sensor.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c0-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c0-bcm2708.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c1-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c1-bcm2708.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/lirc-rpi.dtbo to /usr/share/rpikernelhack/overlays/lirc-rpi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pi3-act-led.dtbo to /usr/share/rpikernelhack/overlays/pi3-act-led.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pi3-disable-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-bt.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pi3-disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-wifi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pi3-miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-miniuart-bt.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/raspidac3.dtbo to /usr/share/rpikernelhack/overlays/raspidac3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/rpi-cirrus-wm5102.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-dac.dtbo to /usr/share/rpikernelhack/overlays/rpi-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-display.dtbo to /usr/share/rpikernelhack/overlays/rpi-display.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-proto.dtbo to /usr/share/rpikernelhack/overlays/rpi-proto.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdio-1bit.dtbo to /usr/share/rpikernelhack/overlays/sdio-1bit.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdtweak.dtbo to /usr/share/rpikernelhack/overlays/sdtweak.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-hw-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-hw-cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.9.24+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.9.24+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.9.24-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.9.24-v7+ /boot/kernel7.img
Setting up libraspberrypi-bin (1.20170427-1) ...
Setting up raspi-config (20170503) ...
Processing triggers for initramfs-tools (0.120+deb8u3) ...
Processing triggers for ca-certificates (20141019+deb8u3) ...
Running hooks in /etc/ca-certificates/update.d....done.
pi@raspberrypi:~ $
Reboot, non working condition
Rex Core Logs
RPiDrv - unable to get Rpi Version, assuming V1.
Linux raspberrypi 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux
pi@raspberrypi:~ $
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
pi@raspberrypi:~ $
processor : 0
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
Hardware : BCM2835
Revision : a21041
pi@raspberrypi:~ $
CPU(s): 4
Socket(s): 1
pi@raspberrypi:~ $
Sorry for the long log, but now I see that this is from updates. On all of the fresh installs after initial GPIO loss I always do updates first due to the fact that this system is on network with internet access, and I have to have python available to run external code that RexCore acquires. On all of these trials I have not even installed python nor pip extensions.
Thanks again,
Thanks a lot, we are on it! I'll let you know.
The problem was located. It was caused by the latest changes in Linux kernel for the Raspberry Pi. The newest version of REX solves the issue (at least on all the Raspberry Pi models we have here). Please upgrade to version 2.50.4 and let me know.
Thanks again for reporting the problem and for your prompt responses.
jaroslav_sobota,
Sorry for the delay but work has been crazy last few days but I am so glad to report that on Raspberry Pi II all is well. I have installed all updates, installed python pip packages, and webmin. And all GPIO's are working great. I will test all on Pi III and report back, I am sure this will work fine but I know kernels can be funny.
Thanks so much for all of your hard work,
Gizmo
REX Team & jaroslav_sobota,
As always REX engineering team is the best. Quick to investigate all issues, and have them resolved and keeping end users posted every step of the way.
Thank you much REX,
Gizmo
