#1 2017-05-11 05:42:19
mikeyh
PWM on Monarco Hat
Hi All,
I need to PWM a MOC3023 optocoupler from the Monarco Hat. I'm not 100% sure on how to do this as the MOC3023 requires 3v3 and the digital outputs are 5-40V. Whats the best way the achieve this? The MOC3023 needs to be driven by 5mA.
Cheers
Mike
#2 2017-05-11 09:54:10
Re: PWM on Monarco Hat
With a series resistor of 470 ohm you should be fine I guess. This will guarantee the 5mA you need to trigger the MOC3023 and the digital outputs can handle a current up to 1A so no problem.
#3 2017-05-11 20:48:18
mikeyh
Thanks scoobsalamander,
Do you now if I can use the 5v from the Monarco Hat or should I supply a sepaerate 5v?
Cheers
Mike
#4 2017-05-12 08:38:27
Hi Mike,
feel free to use the 5V output of the Monarco HAT. Alternatively, you can use the 24V OUT and a 3k3 resistor.
@scoobsalamander: Thumbs up!
#5 2017-05-13 00:51:58
mikeyh
Awesome thanks Jaroslav and scoobsalamander
Just to double check. Is that the 1-wire 5v or the gpio 5v? and how much current can the 5v provide?
Cheers
Mike
#6 2017-05-13 15:10:28
Hi Mike,
it's the same 5V which power the Raspberry Pi itself. The polyfuse limits the current on "1W 5V OUT" to 100 mA continuous.
#7 2017-05-15 20:33:44
mikeyh
Thanks for the help Jaroslav, Just making sure I keep the smoke in!
