#1 2016-12-19 20:09:31
et0
New user, getting started
Hi all,
I am attempting the "getting started with Rex and Raspberry Pi" tutorial but am having some problems.
The core seems to be installed OK and I can download the tutorial code.
But then when watching it execute, it doesn't behave as the document says.
1) I have the Y output from the AND_ block connected to the U input of a TIMER_. When monitoring both, I can see that the Y output is on but the U input is off.
2) If I connect the U input of the TIMER_ directly to a cnb_switch, I can indeed turn it on.  But, the timer still doesn't work - rt stays at 0 and Q also.  (The timer is set up as delayed on and pt=5).
What am I doing wrong, can someone advise please?
#2 2016-12-20 10:36:55
Re: New user, getting started
it seems that the TIMER_ block is not executed.
The reason can be that you accidentally checked "HALT" checkbox in TIMER_ block properties - see screenshot:
If your issue persists, please, let me know.
Good luck with your project!
#3 2016-12-20 11:41:36
et0
Hey Tomas, thanks for the quick assistance.
Yes that was it!  Simple but very confusing mistake smile
Great, now I proceed and hope to demonstrate that REX is the right tool for the job - a heating system with various controls including MODBUS, need for local and remote HMI and some data logging.
Best regards
Evan
#4 2016-12-20 12:42:53
Hi Evan,
I'm glad I could help. We are aware that online monitoring doesn't display any info about HALTED function blocks - it is already on our future feature list.
REX should be able to fulfill all requirements of your project - according to your brief description. Let us know about your progress.
#5 2016-12-21 01:26:27
et0
Hi again,
I carried on with the tutorial for Raspberry Pi, and found one other thing which tripped me up:
"in the folder with the project files, create a hmisrc subfolder. Inside this folder, create
a file named index.html.js and edit it with your favorite text editor".
This doesn't work. Later in the text it refers to index.hmi.js - that does work!
Evan
#6 2016-12-21 08:13:44
Hi Evan,
you are right, that is a typo in the documentation. The source file must be named index.hmi.js. I have updated the documentation:
https://www.rexcontrols.com/media/2.50. … Pi_ENG.pdf
Sorry for your troubles and thanks for reporting this!
Kind regards
