What can be the reason why a newly created TRND is not showing up in the assigned archive?
The archive was already used for other TRND function blocks but they all have a unique ID's.
Solved.....as my archive already contained a few days of data it takes a while before the new ID's show up in the list in REXview's ARC graph window. The loading of the graph takes also a lot of time once you have a lot of data.....
It seems that every single data point is loaded to build the graph....(as I only have a limited amount of pixels on my monitor to visualize all the data it would make sense to load only the data which is needed to draw the graph.....I guess.....)
Hi scoobsalamander,
thank you for your comments - we are aware that archives in the current version are not fully optimised. We will improve it in future versions.
