after adding two ALNI blocks to my task I'm receiving this error:
validation error - 213 (Range check error) (...)ALNI:id
Tried to change id of the ALNI blocks with no success (they are unique).
Any hints?
OK, values "1" and "2" seems to be working.
There is some limit on this id for ALNI block?
My TRND blocks have different (much higher number) id and there is no problem.
Hello Hubert,
thank you for sharing your findings. It is a bug. However I tested it also in our Beta version and it works well, it has already been fixed.
Unique item ID should be in the range from 1 to 65535. Please, note that this number should be unique among all archiving blocks.
If you will face some more difficulties with ALNI block you can use ALN instead. The only difference is that ALN has no external inputs. As a workaround you can use SETPR/SETPI blocks to change the inner parameters of ALN block, which is in fact the same as using the external inputs.
