In my project I have some integrators running to totalize the kilowatts measured by means of a current trafo + voltage measurement.
All this is working fine but every time I download a change to my project I loose all the total values and after restart they start at zero again.
What would be the easiest/best way to store these values?
Hey scoobsalamander!
You can try to use FB called SGSLP (Set, Get, Save and Load Parameters). For more details see documentation.
Wouldn't this result in a big amount of write/read cycles on my SD card?
Maybe I can constantly update a record on my MySQL dB (on external server) and during a restart of the RasPi the latest record will be read during start-up to give the block(integrator) an initial starting value......just a thought...
(but a possibility to keep values and parameters stored in a non-volatile memory I would like to put on the wishlist )
