#1 2015-11-02 15:25:35
nadorffn
PID Control with REXDuino
I would like to set up a PID control algorithm where;
if the input voltage (0-5V) to pin A10 of the arduino is below the setpoint,
then PIDU block calculates an appropriate output voltage (0-5V) to pin (ex DO5_PWM).
I have worked through the REX examples for both the RPi and the REXduino but have not seen anything quite like this. Any help would be appreciated.
-Nick
#2 2015-11-03 21:42:11
Re: PID Control with REXDuino
Find the example attached. The LIN blocks scale the signals to 0-100% range, change it to 0-5 if you prefer.
As a side note, the PIDU block calculates appropriate output even if the input is above setpoint. Why do you want to implement the IF condition?
REXduino_master.stl
X_UNO_PIDloop_task.mdl
X_UNO_PIDloop_exec.mdl
