I am using REX Control System with Inkscape for HMI. While analyzing the "04_PoolAutomationInkscape" example, I have downloaded the exec file into the Raspberry Pi. I can connect with RexView tool. Now when I opened the IP address in web browser I am getting the following errors and the time is also not showing.
13:03:00 Adding group F_MODE failed!
13:03:00 Item F_MODE: pool_task.MP_BUTTON:BSTATE error -106: Connection string not found!
13:03:00 Adding group READ_GROUP-0 failed!
13:03:00 Item lights: pool_task.NOT_LIGHTS:U error -106: Connection string not found!
13:03:00 Item pump: pool_task.NOT_PUMP:Y error -106: Connection string not found!
13:03:00 Item filtmode: pool_task.RS_NOFILTER:Q error -106: Connection string not found!
Please suggest me to overcome this problem since I am very much interested in using the REX Control System. Thank you!
First of all, try to check if both "lighttpd" and "RexWSTcp" processes are running on your Raspberry PI (e.g. using command ps -xa).
Did you make some changes in the "04_PoolAutomationInkscape" example or are you using exactly the one you downloaded from GitHub? If you made some changes, can you please attach your source .svg file?
