#1 2016-03-30 22:44:39
contactform
Exit routine in REXLANG
When exactly does the "exit(void)" routine in the REXLANG function block run?
#2 2016-03-31 09:48:08
Re: Exit routine in REXLANG
The exit() routine is executed when RexCore is correctly terminated (e.g. at system shutdown) and also everytime when a new project is downloaded (prior to switching the original and the new executive).
#3 2016-03-31 12:39:05
Therefore, it is mainly used to close socket communications to be sure to open the socket again after swapping the executive.
