Is there a way to pass rex variables to the node opcua server to fill in the stuff like is shown in MyVariable below.
/*global require,setInterval,console */
var opcua = require("node-opcua");
// Let's create an instance of OPCUAServer
var server = new opcua.OPCUAServer({
port: 4334, // the port of the listening socket of the server
resourcePath: "UA/MyLittleServer", // this path will be added to the endpoint resource name
buildInfo : {
productName: "MySampleServer1",
buildNumber: "7658",
buildDate: new Date(2014,5,2)
function post_initialize() {
console.log("initialized");
function construct_my_address_space(server) {
var addressSpace = server.engine.addressSpace;
// declare a new object
var device = addressSpace.addObject({
organizedBy: addressSpace.rootFolder.objects,
browseName: "MyDevice"
// add some variables
// add a variable named MyVariable1 to the newly created folder "MyDevice"
var variable1 = 1;
// emulate variable1 changing every 500 ms
setInterval(function(){ variable1+=1; }, 500);
addressSpace.addVariable({
componentOf: device,
browseName: "MyVariable1",
dataType: "Double",
value: {
get: function () {
return new opcua.Variant({dataType: opcua.DataType.Double, value: variable1 });
// add a variable named MyVariable2 to the newly created folder "MyDevice"
var variable2 = 10.0;
server.engine.addressSpace.addVariable({
nodeId: "ns=1;b=1020FFAA", // some opaque NodeId in namespace 4
browseName: "MyVariable2",
dataType: "Double",
value: {
get: function () {
return new opcua.Variant({dataType: opcua.DataType.Double, value: variable2 });
set: function (variant) {
variable2 = parseFloat(variant.value);
return opcua.StatusCodes.Good;
var os = require("os");
* returns the percentage of free memory on the running machine
* @return {double}
function available_memory() {
// var value = process.memoryUsage().heapUsed / 1000000;
var percentageMemUsed = os.freemem() / os.totalmem() * 100.0;
return percentageMemUsed;
nodeId: "ns=1;s=free_memory", // a string nodeID
browseName: "FreeMemory",
dataType: "Double",
value: {
get: function () {return new opcua.Variant({dataType: opcua.DataType.Double, value: available_memory() });}
construct_my_address_space(server);
server.start(function() {
console.log("Server is now listening ... ( press CTRL+C to stop)");
console.log("port ", server.endpoints[0].port);
var endpointUrl = server.endpoints[0].endpointDescriptions()[0].endpointUrl;
console.log(" the primary server endpoint url is ", endpointUrl );
server.initialize(post_initialize);
Thank you for your question. At the moment I cannot help with this one.
A native OPC UA server for the REX Control System is in development. As soon as we have it ready, I'll let you know. Thanks for your patience.
