Is there any way to implement CPU redundancy using REX with raspberry. For example, There are two raspberry pi's running REX and there is one analog I/O module connected to the first raspberry pi's I2C bus and the second analog I/O module connected to the second raspberry pi's I2C bus .
Both the raspberry pi's are connected over TCP/IP or I2C where one pi is master and the other pi is a slave. The program is running parallely in both the raspberry pi's but only one of them is active and controlling the I/O module. If the first raspberry pi (active) fails for some reason, the second one takes over with a bumpless transfer thus saving the process. People connected with the process industry will find this familiar.
I require this because we have developed some solutions for the Power plant that i am working at but they have not been approved by top management because it lacks controller redundancy. Please help.
Yes there is! I just added an example to GitHub repository of REX Control System examples. Here is a direct link to Controller redundancy example.
For this project, you will need the licence for using Advanced function blocks on your Raspberry Pi.
Hope this helps!
Brilliant !
