#1 2018-01-07 21:18:52
mikeyh
Local HMI on RPi
Hi All,
Silly question...!
I have my Monarco Hat running on a pi3, using Raspbian Stretch Lite. If I were to add a raspberry pi display or monitor to the HDMI port. How can I display the REX HMI? Is it as simple as installing a browser, or is there more to too it if using Stretch Lite?
Cheers
Mike
#2 2018-01-08 08:52:15
Re: Local HMI on RPi
Hi Mike,
not silly at all. You need to install a browser and enable graphic environment, which requires a bit of Linux magic. Is switching from Raspbian Lite to full Raspbian with desktop an option?
#3 2018-01-08 19:45:33
mikeyh
Switching is an option. My original use for using lite was due to space on the SD card, I have a much larger one now. What would you recommend? Updating to the desktop version?
Cheers
Mike
#4 2018-01-09 09:39:34
Hi Mike,
yes it's probably the easiest to switch to Raspbian with desktop. Afterwards you can set the browser to start automatically on startup and display the HMI page.
#5 2018-01-09 20:01:46
mikeyh
Will do, thanks for your help Jaroslav.
Cheers
Mike
