Is there a way how I could use a variable inside the HMI webpage (javascript) from within REXcontrol?
Websocket?
Reason : I need to control the x,y coordinates from the two points of a SVG line. At the moment this is not supported in the REXHMI Designer.
How about reading the value via REST API (i.e. using the HTTP GET request)?
Or, you can always create your own component for the RexHMI Designer...
Are you trying to build your very own HMI or what is the use-case?
PS The scaling animation could partially solve the problem but I guess you have a reason not to use it, don't you?
I have a heating control system running which uses the LIN function block for calculating the needed water feed temp by the outside ambient temperature. But in addition I also have a LIN function block to calculate the wanted return water temperature, if this one is too low an adjustment to the feed temperature will be done. This compensation has also a maximum and this is also calculated with a LIN FB. The x and y coordinates of the interpolation points are not static and will change constantly....
On the HMI I want to display a graph with these lines (3) and at the same time I want to visualize on the same graph the measured water temperatures (feed & return) and the outside temperature.
At the moment I'm trying to go through the tutorial you once wrote regarding the creation of a custom button....but it's not so easy if you are not a javascript/RexHMI guru ...... :-)
By using the scaling animation the line thickness will also change, correct?
I had some success with the rotate function but then I had to calculate the rotating angles of the lines in Rexcontrols, it's working but I didn't like it...... :-)
Yes the scaling animation also changes the thickness of the line :-(
At the moment you have to stick with your workaround or create your own component for the RexHMI Designer.
This is not a mainstream request, therefore we could develop such component for you only if you were OK with a paid service.
Thanks for the offer but as this is just a hobby for me I prefer to do it the hard way and try to make my own component.
If something useful comes out of this I will post it here.....
