#1 2017-01-25 23:23:31
mikeyh
DS18B20 on raspberry with monarco hat
Hi All,
I have got some 1-wire temperature sensors (DS18B20) running on the monacro hat using the OWS driver. What is the best way to now change the resolution. I only really need to read temperature down to 0.1 or maybe even 0.5 of a degree. I will also get a quicker sample rate. I believe by default the sensors come set at 12bit, I'm thinking 10bit will be perfect. Just not sure of the best way to change it.
Thank you in advance
Mike
#2 2017-01-26 08:13:41
Re: DS18B20 on raspberry with monarco hat
Hi Mike,
just change e.g. /28.2022DB060000/temperature12 to /28.2022DB060000/temperature10 in the OwsDrv driver configuration.
Have a nice day!
#3 2017-01-26 09:03:37
mikeyh
Wow that easy.... thanks Jaroslav
