Hi, RexHMI Designer shows an error when trying to edit an element no matter if I create a new file or using some existing project.
This only happens on one particular PC, several other PCs have no problems with RexHMI Designer at all.
It is a fresh installation of Windows7 Ultimate 64bit, REX installation: REX-2.50.1.7567-x86.exe.
Later on I tried to uninstall REX and install again, but still the same behavior.
Other tools (RexView, RexDraw) work perfectly.
Is there a way of debugging what is happening to RexHMI Designer?
thank you for the report.
1) Can you successfully Compile the example (RPi examples / 04 PoolAutomationDesigner) ?
2)Would it be possible to have some Remote Desktop session to diagnose the problem remotely?
Ondrej
Unable to compile 04 PoolAutomationDesigner, ready to provide remote desktop access via TeamViewer...
