Hello again,
I messed something up.
Suddenly, after some change in database config (ODBC) my rexcore was not starting (on RPI 3, raspbian jessie) so I uninstalled rexcore and installed it again.
Now, when I try download configuration to my target i see an error:
Error: REX Module error - some driver or block is not installed or licensed on target device (code -108)I checked services - rexcore is running, rexenv is NOT running.
Checked on RexView and my device is licensed.
Please help, again ![]()
Hi Hubert,
can you please see the System log in RexView? It will give you (and also us) some more information... Thanks!
Hi Jaroslav!
after booting/running rexcore I have warnings and errors (but it is the same like before my issue):
Unable to load authentication database from "/rex/rexcore/auth.rex": File open error
Unable to locate CA certificates in "/rex/certs/cacerts"
Unable to load control algorithm from "/rex/rexcore/exec.rex": File open error
Unable to load HMI from "/rex/rexcore/hmi.rex": File open error
RexCore is runningafter failed attempt to load configuration:
ReadStream: unable to load module 'AdvBlk', error = -108Offline
AND i reinstalled and wiped rexcore directory, entered license key once again - no success ![]()
AND rexenv still not running..
It seems that the package rex-advblkt is not installed. Please run
sudo apt install rex-advblkton your Raspberry Pi. Then try downloading your algorithm again.
Let me know.
Thank you for your help.
Did as you suggested, but also needed packages:
rex-dbdrvt
rex-mbdrvt
No it seems everything is OK! Thanks again.
Is this OK that those packages are not installed with rex-core?
regards
