#1 2016-11-26 16:01:35
farcouet@yahoo.es
sleep function within rexlang
I have been trying to use the sleep function in the rexlang block (so I can write to I2C wait and then perform a read for the ADC).
My problem is that I get the following error when compiling:
Error compiling file 'ads1115.c' (line 75): function 'sleep' is not declared
Error 125: The configuration validation error occured in:
Error 126:     Validation error -220 (REXLANG compilation error) in the pin 'pool_task.ADS1115:srcname'
I am not sure to understand why as the sleep function is supposed to exists in Rexlang. I am not sure what I am doing wrong.
Fred
Documentation:
void Sleep(seconds)
Stop execution of the block’s algorithm (and whole task) for defined time. Shortest possible time is about 0.01s, but depend on platform.
#2 2016-11-28 10:18:55
Re: sleep function within rexlang
Hi Fred,
the functions in REXLANG are case sensitive - try to use Sleep(seconds) instead of sleep(seconds).
Please, be aware that the Sleep function will stop whole task - so it will artificially extend the sampling period. It can be critical for some sort of applications. I would suggest to use some simple switching logic witihn REXLANG so that every odd tick you will perform write and every even tick read command.
