is there a function block for communicating between 2 devices running RexCore?
Example : I would use the input of my Rasp 1 to control an output of my Rasp 2 via RJ45 / internet .
thank you for your reply
Hey geocipo,
thank you for your question. There are two main approaches I'm able to think of now:
Communication using "RDC" block - see RDC data exchange example (Note: for this approach, you will need the licence for using Advanced function blocks on your Raspberry Pi)
Communication via UDP/IP using REXLANG block - see Data exchange via UDP/IP example
I hope the above is useful to you.
Thank you , I test this as soon as I have time
